1 - 4 of 4 Posts
Yes I have googled this but where can I find the 2 cone filters that I need for when I gut the stock airbox after removing the plastics to go for a more naked look. All info on this would be great. I know theres 2 filters I will need where what size. Is all I need is the filters and cant find the info anywhere. Thanks ahead
You need to save the boot going from your carb to the airbox. You put the pod filter on the airbox end of the boot. You need the boot to route around the shock.
The crankcase breather is a direct fit.
Any aftermarket taillight or turn signal set up can be made to work.
1 - 4 of 4 Posts
