1 - 6 of 6 Posts
SOLD: Lancaster, PA
2001 TrailWay with ~3,455 miles​
one owner; bought new 5/14/02 with 0 miles
excellent condition but for 1 OEM scrape on plastic above left rear turn signal
clean, clear title - no liens
ridden every summer - never stored (I'm 66)
99.9% back roads use - too much suburbia, too little dirt
always well maintained and garage kept​
new OEM battery this spring 2012
carb cleaned of excess powdered yellow ethanol residue this spring 2012
(now use only stabilized, ethanol-free fuel)​
home made luggage rack, wood with locking American Tourister train case mounted
(the original recession rack on this forum; supported at rear by turn signal mounts)​
mods applied:
oversized footpegs - ebay style
carb main jet needle shimmed; idle mixture screw opened and enriched
#128 main jet installed
hex head float bowl screws installed on carb
carb air vent hose modified, for deeper water crossings
hex head seat bolts installed; hex wrench added to tool kit
2 OEM keys, plus key code (to order new keys)
original printed Yamaha owner's manual + 2 related OEM manuals
service manual on CD (pre-2001 + separate update)
new spares: carb bowl gasket, idle mixture screw set & extra needle washers
OEM #126 jet & carb float bowl screws
set of bolts & spacers to raise front fender
velcro strap to hold small water bottle beside headlight
original footpegs go with bike
no rust; no dings
****$2,100.00 or B/O**** Pickup or local drop off only
****NOW $1,950*****
Here are some pictures of the bike:
left side
left front
engine left
right side
engine right
This TW200 is still available. I've added some pictures so you can check it out. The pictures are huge, so be sure to click on them and thus expand the images. Has to be one of the nicest 2001's around. Check it out!
- - - Happy trails, Jim
Hello im interested. Im from the monroeville area which is about 4 hours away from Lancaster. I was wondering how far you would come when you said "local drop off"
Thanks, Luke
You can email me at [email protected]
This TW 200 remains available. I spent yesterday getting the chain cleaned and re-lubed, giving the TW a fresh fill of semi-synthetic Yamalube, and getting the battery topped off with some fresh acid/water mixture. And I still marvel how close to new this bike looks. Even the chain and rear sprocket look like they just stepped out of the showroom, except for some road dust and spots of O-ring chain lube.
- - - Movin' on cause I'm retiring, Jim
NEW PRICE
This T-dub is still in great condition, has just a few more miles on it, and hasn't been claimed yet. Some tire kickers, a few kibitzers, but no one's had cash in hand. So the new price is $1,950. Come get it before I decide to keep it!
- - - Starting to waver, Jim
1 - 6 of 6 Posts
