It might be a stolen idea, but they used their own photos.Son ofa Bitch!
They stole my R-clip seat pin system! Not so much as a thank you or even a how-do-you-do either.
I wonder if they know I have a patent on that. Ha!
But I'm ready to forgive, just toss me a bone: How about a rear disc brake assembly for my idea and photos you used to copy my idea.
TW200 Easy Seat Pin System | bradley performance (bradleyperformanceproducts.net)
it's funny that they claim you need lock-tite to keep the stud in place so the clip will hit the hole. You don't. The R clip will keep the threaded pin from unscrewing. See? I just improved their profit margin with that suggestion.It might be a stolen idea, but they used their own photos.
Sent from my Pixel 6a using Tapatalk
First, thank vwbobby for being the liaison between Brad and the forum.Some updates from Brad:
"Good news. It's not easy but it is possible to use the rear disc conversion with the fat tire conversion. Everything is working great."
I sent the question to Brad. When he replies I'll post it up.First, thank vwbobby for being the liaison between Brad and the forum.
Second,does he know if the fat tire conversion will work with a 2" extended swingarm? I'm willing to front the funds on the first extended swingarm version of the rear disc set-up. I'm hoping that is with the larger disc and dual piston caliper upgrade.
What type of extension do you have? Is it a JNS or the stock swingarm cut and lengthened?Second,does he know if the fat tire conversion will work with a 2" extended swingarm? I'm willing to front the funds on the first extended swingarm version of the rear disc set-up. I'm hoping that is with the larger disc and dual piston caliper upgrade.
The stock swingarm was cut and extended 2".What type of extension do you have? Is it a JNS or the stock swingarm cut and lengthened?
Brad replied - "I really need an extension set to prototype with. I currently don't have one. I think the brake hose is going to be a little short. I can probably come up with a longer hose if so I will have inventory here Monday and more hubs machined this week."
Yes sir, that's what I'm thinking as well.The stock swingarm was cut and extended 2".
Since all the tabs and stuff are stock, I would presume a longer brake line is all that is needed. If I knew what length hose is in the kit, then I'd simply get one 2" longer and order and request a kit without the hose.
The rear hose eye to eye is 20". Standard 10mm banjo.If I knew what length hose is in the kit, then I'd simply get one 2" longer and order and request a kit without the hose.
That is the 12" trailer wheel, right? Not 14"?
They made a change - "we have decided to make a change to a slightly bigger disc and dual piston caliper at the last minute."In one picture there is a double pot caliper , and a single in another.
