1 - 14 of 14 Posts
I think it's my turn! After doing some (many hours spent) research on the forum I gathered many ideas and bough a bunch of parts I though would be nice upgrades to my TW200. I got a whole box full of goodies this afternoon. I feel like a kid at Xmass.
Here I have :
Shinko 244 4.60/18 front tire
Moose Racing heavy duty tube (I know Bridgestone makes one 1mm thicker but the dealer couldn't have them)
Acerbis Super Moto front fender
Protaper SE ATV Hi Handlebars
Pro Grip 714 Dual Sport Grip
Chinese wider foot pegs and smaller springs
Generic folding foot pegs (will be a third set, for the kid)
JT 14T front sprocket
JT 47T rear sprocket
EK O-Rings chain
Fuel filter 90 degrees
All that for a total of about 500$!
The only missing things are a XT225 fuel tank (which I bought last week but doesn't seem to have shipped yet...
) And some handguards that are supposed to be in the mail.
Now I'm waiting for the weather to clear so I could install all that stuff.
I'm still debating how I'll mount the front fender. I've been reading a lot of posts about it and think the option to drill and tap 2 small holes for bolting the fender directly in the lower tree is the cleanest one. If I was not worried about weakening that lower tree I would do it strait away.
The wider peg instalment will be a bit challenging since they are not direct fit on the TW200 and were not meant to be used on this bike. I had to order some smaller springs cause the ones on the TW were too big to fit in and I'm planing some metal grinding in order to have them set right.
I'll keep you updated as things progress.
Here is what I did for my fender. It holds well and you can protect the integrity of the lower triples too. This is the step by step that someone else posted.
I also put on a supermoto fender.
Start off with a cardboard prototype and go from there....
I cute & rounded the bracket and cut off the corners too. It made it look cleaner.
My friend helped me do this. And lastly, he showed me how to use a circular sander to give it a nice clean polished finish too.
Sorry for the big photos.
Sorry for the huge pics
hey brock,
your that bracket aluminum or steel?
looks good!
Looks good Brock! I may consider doing a dual fender now that I know I wouldnt have to drill into the tripletrees.
What kind of acerbis disk cover and fork shield are you using. I have been wanting to get some of these but wasnt sure which would fit the tdub. Any modifications needed? My forks are getting green stains on them and it bugs the $h:t out of me.
[quote name='PalmStateCrawler' date='22 April 2012 - 01:28 PM' timestamp='1335126486' post='43604']
Thank you by the way...That is an old school XR 400 cover. But back in the day they were pretty generic (from what I learned searching for them). I paid $40 for it on ebay. It came with the fork tube protector too. I did it simply for VANITY reasons. I admit to being an MX snob versus the hollow bikes. \
I just made a call to my friend whose dad helped me with the fender...neither of us are if it is steel or aluminum. Actually it is aluminum. I just attempted to put my daughter's pink heart magnet and it didn't stick. ALUMINUM.
I bought early 90's YZ 80 forks and I hope to soon transition to the hybrid forks (TW lower legs and YZ upper tubes). Doesn't increase fork travel, but in does increase ground clearance and it will level out my TW since I have a long banshee shock on the back.
Discussion Starter · #10 ·
Discussion Starter · #11 ·
Brock, I took the super moto fender idea from you
Making a bracket is a good idea, but I don't like how it looks...
I know I'll probably end up doing it since it seems to be the sturdiest way to install that fender.
No I can't. They are not the same. I'll show you why when I put them on next week (I hope).
Ok. I'm curious to see cause they look just like the ones I put on.
Just a word to the wise. I put my fender a little farther back than I probably should have, therefore, on hard bumps it would bottom and hit the fender thus tearing up the lower part of the fender. I ended up snipping the fender up to just under the first vent. I probably could have put the fender a half inch or more back. But after snipping it, it works fine.
I initially thought my forks seals had blown, but that wasn't the case. It was because of the placement of the fender.
1 - 14 of 14 Posts
