While reading the threads about sprocket options and selections, I had a thought. Is there any compelling reason as to WHY the rear axle nut must go on the RIGHT HAND side of the bike?
When I recently changed my rear sprocket, I was unsure whether the chain would be long enough to accommodate a larger sprocket, so I only installed 3 bolts - and would install the remaining three if it worked - but I was thinking that IF the axle-nut was on the LEFT hand side, I could withdraw it partially, remove (or replace) the sprocket and then slide the axle back in without having to remove the entire wheel.
So...can it be done? Can the axle-nut go on the right side instead of the left? I can't see any reason why not!
