Hello, I was wondering if some one could can help me with how to disconnect the speedo cable from the speedometer so I can lubricate it. I both a 2009 with 500 miles on it ( almost new ). And while doing the maintenance on the the front wheel I disconnected the speedo cable at the wheel and there was a little bit of rusty water, so I wanted to lubricate it from the top.
Removed the small clips on the bottom of the speedometer,had the speedometer in my hand, removed the two small screws that seem to keep the inside mechanics connected to the casing and that's it. Is the rear cover clipped or clued?( did not want to force anything).
Thanks in advance
Also is a lubricant like CABLE LIFE good for the speedo cable? And is a normal lithium grease good for the bottom part of the speedo mechanism ( wheel hub ).
Thanks in advance
