1 - 11 of 11 Posts
After changing my front tire to the Shinko SR244 "Golden Boy" size 5.10-18, I wanted a little extra clearance between the tire and the front fender. Initially I used some solid 3/4" spacers. These provided the extra clearance that I was looking for, but on a recent offroad ride I bottomed the front end hard enough for the bottom triple clamp to leave witness marks on the front fender brace and fender.
Fortunately, the contact was not enough to break anything but I figured it was time to try a different approach.
Here are some compression springs I found that are just over 1" in length and about 7/16" in outside diameter.
I replaced the solid 3/4" long spacers that I was using with these compression springs.
When these are secured, they give me about 11/16" of lift, or slightly less than the solid spacers. However, they will also now allow compression of approximately 1/8".
What else can I say? I was bored today.
Great spring solution. I had same concern about bottoming out and thought of same solution with springs. Glad to read your idea works (they say the true measure of someones intellegance is how much they agree with you). Actually I had read about your 1" spacers and was going to discretely personal message ypu and question you whether it bottomed out on trails since you also run a Duro ATV tire and thus trail ride. Do the springs allow fender to flex on bumps or at speed? The few springs I saw @ store that would compress short enough seemed too weak to rigidly hold up fender untill needed to deflect. Your springs look perfect. Good looking installation too. This should help prevent the dreaded "mud-lockup" from clay and mud we occassionally get where the front tire will not turn untill freed of mud nd debris.
Hi Fred,
I can't honestly say that I know what these springs do on bumps or at speed, I pretty much put them on and forgot about them. My guess is that they are stiff enough to prevent flexing and I have not bottomed out the front end since putting them on - so from my perspective they doing what I wanted them to do.
Hope this helps,
Brian
Banned
I fixed it Tommy!!!! 10358858_10203002884585143_1557941751_o.jpg not compressed. 10439226_10203002883465115_1883150118_o.jpg full compression.
Banned
I got my springs at ace hardware. 10467502_10203003133671370_297787690_o.jpg 4 in a pack just what I needed. 10449316_10203003137111456_1644215086_o.jpg
1 - 11 of 11 Posts
