1 - 4 of 4 Posts
We have our own, and it's already calibrated to the TW ransmission ratios.
You'll find it cleverly disgused as "Sprocket/Speed Calculator" in the tech section.
You'll find it cleverly disgused as "Sprocket/Peed Calculator" in the tech section.
Thanks, I saw that one but did not realize it was all ready calibrated and did not know what numbers to fill in. Very NICE! Now I know what the redline is. Still not sold on moving away from stock 14/50.
Fill in a speed. I generally use 55. Hit "calculate" and that will give you the stock rpm @ 55. with stock tires and gearing you should get 7,042 rpm in 5th at 55.
Then plug in other-than-stock ratios to see how they affect rpm at a given cruising speed.
1 - 4 of 4 Posts
