1 - 4 of 4 Posts
I've got a dead stator see https://www.tw200forum.com/threads/stator-coil-question.67583/#post-1038305
I've found replacements on Ebay & Amazon that says that they fit all the TWs (125,200 & 225) from 1999 to 2017. Mines a 2003 TW125
Problem is that it appears to have 2 additional bullet connectors - see picture below
203953
Anyone know what they're for and if I can just leave them un-plugged?
Cheers
Tris
Discussion Starter #2
I pulled the trigger and ordered it as it seems that the two bullet connectors are either end of the same wire and run in the black sheathing only, so could be chopped off :cool:
If it works when it arrives I report back and close this topic out
Yes you can chop it off. I suspect it should go to the neutral switch if connected that way
1 - 4 of 4 Posts
