I sent some questions to STI about the DOT approved Black Diamond and received a reply.
Here's what I'm talking about:
Here's my email:
There is an ongoing discussion on DOT approved tires on our Yamaha TW200 forum. As you might know, the TW200 sports larger tires than most dirt bikes, straight from the factory. Owners are running Maxxis Bighorns, Duro Power Grips, etc so we know that 8s and 9s (depending on the tire) do fit inside our swingarms. We would like to get an aggressive tread ATV tire that is DOT approved and yours looks like a maybe.
Not looking for an approval of the mounting but I've read comments that the tire is slightly narrower and shorter than expected when mounted - good things for us. Our stock tires are 180/80/14 but we stick lots of 26x8/9x14s on. Can you tell us what the inflated width and tire height would be on our rims? Thanks.
And here's their reply:
"Hello Thomas,
All of our Black Diamond tires are DOT Approved. The rear Black Diamond tires do run a little narrow, but the front size are closer to their claimed width. Both the front and rear tires are very close to the claimed tire height (OD).
We won’t be able to provide specs for you application, but I have attached our tire spec sheet that give all of the factory specs on the tires: section width, OD, load ratings, speed ratings and weights. Please keep in mind that all of these specs are based on a 7-inch wide wheel and the tires being inflated to 7 psi. Typically we adjust the recommended air pressure depending on the application; for example we recommend a minimum of 12 psi for a side by side (UTV) vehicle.
Hopefully this information helps.
Thanks,
Jamie Chisholm
STI Tire & Wheel"
This is the spreadsheet STI sent:
Here's my email:
"Hello Thomas,
Thanks,
Jamie Chisholm
STI Tire & Wheel"
