1 - 20 of 39 Posts
Today I took half a day off to get my Tdub inspected....
Getting three or four hours off isn't hard..
Anything more tends to require an act of God...
I couldn't find the key so I thought maybe l left
it under the seat strap.
( I put it there sometimes when I'm mucking about )
Pulled the cover back and there it was...
In the ignition..... In the on position....
Duhh I know genius at work...
It's been that way for over a week now...
I figure the battery is toast..
So one kick and off I go.
Unfortunately to pass inspection all lights and horn must
work without the engine running amoung other things...
A miracle.. The twenty mile ride put enough juice in the
battery to work the lights and horn..
GOOD TO GO FOR ANOTHER YEAR !!!
What's the best way to defeat the kickstand switch
so I MUST shut the bike off with the key.
I don't want to destroy my next battery....
mike from N.C.
Pavlov a memory trick instead. Every time you turn the key off think of your favorite food. After a dozen or so times you'll have yourself getting the munchies every time you hear keys jingle. And you'll remember to turn the bike off.
The only thing I found to guarantee your ignition is turned off is to make sure you ride with other people. They are more than willing to let you know you left the key on. :oops:
Form a habit of always shutting off the bike with the key instead of the kill switch or the kickstand. Repeat this every time for five years. I used to shut off with the kill switch and did exactly what you did a few times, but I never left it for a week. That has probably significantly lessened your battery's life, and Murphy's law will apply.
Now, the only time I will use the kill switch is if bonking on a hill or whenever I must stop the bike with both hands on the bars.
I try to always shut the bike down with the key..
I must have been in a hurry , , dropped the kickstand
And forgot.. ( HOORAY FOR THE KICK STARTER ! !
BEST INVESTMENT EVER ! ! ! )
This is why I never use the kill switch , unless I'm
descending a scary hill.
Yes I'm a wuss..
Mike from NC
Defeating side stand switch in an easy, reversible way is to simply short across the two leads from the side stand switch as they disappear into a female connector adjacent to left frame rail underneath the seat.
In past I've separated the male/female plug then inserted ~2" U-shaped bare thin copper wire into female plug half. Then re-inserting the male plug half leading from the side stand switch makes both a good electrical and mechanical connection.
This is also a quick way to for test side stand switch operation if you think it is the cause of an inexplicable no-start or no-run condition. i.e. if the jumper didn't solve the problem then the side stand switch is not the problem.
I put a piece of this wire to good use one night when it did solve the problem. A just-before sunset tip-over resulted in a no-start several hour fix-it session atop one of my favorite granite bouldery single tracks far from cell coverage or Mrs. Fred's loving arms (Her worry had made her mad when I finally made it home hours late...no loving arms for me:confused:). Normally a 14" piece ( now 12":)) of this soft copper wire joins both left and right side covers pulling their pointed tips inwards against the 4 gallon Clarke tank... keeps knees from snagging on side covers.
Reactions: Workingman
Hopefully I will check into this this weekend when I have the seat off..
But then you can't do this...
Discussion Starter #10
He didn't turn off the damn key...stupid is as stupid does
Hell I can do that without a fancy dismount....
Oops maddmavrick beat me to it
Reactions: Ken
Discussion Starter #11
Maybe I can find a sticker for the gas tank...
.......... TURN OFF THE DAMN KEY...........
to put under the one that says
.......... Turn the gas on dummy ..........,
Here you go then...at 5:35 minutes in. (TW200 content at 2:45 in) bloopers at 6:30.
Thankfully Ohio has NO requirements to "inspect" a mere Motorcycle...take your title in, get a license plate... 🤠
When I moved to CO years ago - I was almost in tears when I heard that "inspection" was not a thing here. Does the VIN match the vehicle? Inspection complete!
We had our first car stolen a few months back. We are not city folks. We live a ways out. Can't see a neighbor. Someone came in and grabbed the keys out of the center console of my favorite mini van and took it for a month and a half.
It was easy for us to figure out a routine for the car and motorcycle keys after that.
Idaho:
1. Possess vehicle.
2. Remit appropriate number of potatoes.
3. Exercise freedom.
Assuming that you lock your house doors, place your ignition & house key on the same keyring. You might forget it in the bike, but the problem will quickly become obvious.
Unless you're used to losing your house key and crawling in thru the window...
It's not a real good idea to defeat the kickstand switch. Do you know why it's there? It's a safety measure. If you ride away with the klckstand down and make a left turn, the stand will hit the ground elevating the rear wheel off the ground, and you know what?" Down you go.
Do not defeat or bypass the kickstand switch.
Just remember to use the key to shut off the bike.
remember when our bikes didn't have kickstand, clutch and neutral safety switches..... how did we ever survive..... well I guess some must not have.....
I'm with troll on this one. When I started riding, the only safety was the ignition switch. Sure, you can take off with the side stand down, but you only ever did it once ......
1 - 20 of 39 Posts
