I'm rather embarrassed to ask this question but I guess its less embarrassing than having my wheel catch on fire or fall off.
I'm installing an All Balls rear axle bearing and seal kit. On the brake side it gets one bearing and no seals then on the sprocket side it gets 2 bearings, then the "manual" (read vague suggestion literature) says oil seal on the inside and dust seal on the outside. Well which ones the oil seal? The smaller OD one or the larger OD one? The smaller fits nicely in next to the bearing but then the larger one doesnt seem large enough to "lip" over the hub.
