1 - 20 of 36 Posts
I am chopping and extending my swingarm 150mm. I thought that I had previously found a post (I can't find it now, though) that stated the swingarm was D.O.M. steel, or drawn over mandrel steel. But that is how it is made, not what it is made of.
So, is the swingarm a mild steel or a chromoly? I want to use like with like for my extension. Any one know what type of steel the swingarm is constructed?
After further research, I have found that mild steel and chromoly spark different colors when cut or ground. Apparently mild steel sparks yellow while chromoly steel sparks blue. Guess I will see what the swingarm sparks...
Mild steel, near as I can tell.
I'm splicing two together for mine. They cut like butter, so I expect they'll weld like it, too.
Old Post http://tw200forum.com/forums/2/98557/ShowPost.aspx#98557
All the specs I can find just say "STEEL" I would think if it was chromoly they would be proud to say so.
Although I do have chromoly sprockets
Thank you! That is exactly the post I couldn't find. I think you are right, it would probably be stamped as XXXX chromoly steel or something. I am hoping to add some new chromoly sprockets soon too!
Thanks.
I was surprised at the 1/16ths thickness; I had expected it to be much thicker. Splicing two together is an interesting idea and I would enjoy hearing about your splicing method. I am just jigging, chopping, welding inserts and capping. Although I am adding plug welds as well.
How much extension are you adding and what are your plans for the brake rod?
150mm's (6") is a lot. I don't have the pieces handy at the moment, not sure there's enough straight section to accomodate that length.
Mine will be about 2 1/2". Cut one swingarm just forward of the snail adjusting pins. Cut the second one's arms off as far forward as the desired stretch.
Splice the two together with a sleeve or spud plates, jig it up and weld. Only one joint.
Ronnydog did his by simply spanning the gap with an inside sleeve. Villageidiot does his using your method. Mine wastes a swingarm. All should work fine given decent weld quality and jigging.
Brake rod for mine will come from a Virago. Yours will likely need a welded extension.
I wasn't expecting 150mm to be a big deal given its the smallest size of the import kits, and VillageIdiot's statement that he can stretch one up to 254mm or 10 inches. I have PM'd VillageIdiot but haven't heard from him yet. I may have to reevaluate the length of my stretch based upon how much insert overlap I can achieve.
As I think more about it, the import kits are likely not stretches of stock swingarms, but rather new fabrications given that they do not appear to have the factory zerk fittings for greasing the swingarm bushing.
Yes, I agree! I will take some photos as I proceed. If I screw it up I can always find another swingarm or import a kit...
Thanks for the replies, this board is great.
Swingarm jigged and plasma cut. I will post more as I proceed.
Village idiot (Colby) extended my swingarm, came out great. He did end up selling his TW though and all his spare parts. Nit sure if he is still on the forum. With regards to the brake rod, I had a Verdugo one but with my 3" extension and ttr225 brake arm(design comes forward rather than straight up like the tw), the Verdugo rod was too long. One benefit of using the ttr225 brake arm, I was able to use the stock tw brake rod.
Josh
Josh
Good call on the TTR arm. The curve would solve the problem. Thanks.
More leverage as well. It took some adjustment but I am able to lock up my bighorn 2 on pavement. Not that you want to, but my rear brake never felt so strong.
Josh
For information...
[url="http://www.sainet.or.jp/~megaton/sub1.html]The manufacturer suspension arms in Japan ...[/url]
OK. An entirely new swingarm, which explains the cost. I was wondering why they cost so much, thought it was importation fees.
Discussion Starter · #17 ·
For information...
Wow-that is some sweet work. Thanks for the link! I doubt mine comes out looking *that* good.
Hello
It's easy to find used extended swingarms in Japan, just have to check on Yahoo auctions or visit stores in Ueno.
Most popular are made by Kijima and are available in black or chromed finish, +150 or +200mm
I wouldn't bother making one by myself.
Cheers
lol @ "made in Kawaguchi" funny one Christddel, Saitama ken is N°1, thanks for the link
Discussion Starter · #19 ·
Hello
Cheers
I looked at the Kijima arms, but they are $500 to 600, which is nearly what I paid for my bike.
Additionally for me, the real enjoyment is in doing as much stuff as I can myself.
hello
sure, it's the same for us, we generally make our swing arms but only when they got unusual dimensions (for 10" wide wheel on our GSXR powered trike for example) but long swing arms are common on TW there and easy to find at cheap prices.
thare are also models from other brands and you can get them for 20,000¥, not same quality as Kijima of course but good enough.
check here
and there
Nihonjin made in Kawaguchi, pretty cool, my wife was born in Omiya
you shouldn't underestimate the second hand market too, many ppl in Europe buy used parts argueing they're more affordable.
Cheers
1 - 20 of 36 Posts
