tall people
3428 Views 6 Replies 6 Participants Last post by  tkrrox
i'm 6'4'' and love the bike but a little cramped...has anyone added foam and reskinned there seat...i'm thinking about 4'' of softer stuff...will the stock cover work or will i have to have one made?
also does anyone make a lowered peg for this bike? i love this thing just trying to make it fit...
thicker seat and add some bar risers that would probably make a big difference.
I actually made a similar post just the other day. I am happy with the seat height (I'm 6'2") with the seat cover on, but I am doing the handlebar risers. One more suggestion, if you have the problem I do with the mirrors only reflecting your arms and not much else behind you (I'm also a bit on the "wider" side), you can purchase a set of mirror risers/extenders. I just ordered mine the other day, and they have yet to show up. Once I get them, I'll make a post on this site.
Dan
Hello Tkrrox,
Are you aware the shock/coil spring are adjustable? There are three (3) positions. U.S. bikes are sold with the adjustment in the center position. To raise the bike a small amount. remove the coil spring and move the circ clip to the next higher position. I just did this and I estimate it added a 1/2" to the ride height.
Hope this helps.
Marty
Dan
Speaking of bar risers, what risers are you using?
Also, where did you get them and do you like them?
I use the tusk univeral risers, from Rocky Mountain ATV. There wasn't as many choices back when I did mine. If I was doing it now I would serious look at Rox Rox or Tusk New Tusk
Hello Tkrrox,
Hope this helps.
Marty
did you notice it doing anything to the geometry....i know with my dirtbike, it will actually change the handling traits...
