Again, I have read all of the comments on the ticking sounds from the top end of the tdub. Mine is a 90 with 3660 miles. I adjusted the valves and again and again and again, adjusted the cam chain and double checked it. It did not tap when the valves had no clearance when I bought it. I couldn't get a .002 in the gap of either the exhaust or intake. I wonder if the valves are crapped up. Has anyone shot carb cleaner in the engine when running to attempt to clean the valves? It only taps when it warms up and it's almost intermittent???It taps more than not.....You can almost heare a slight stutter when it taps. I've used the stethiscope and can't pinpoint the sound even though I can hear it with bare ears! Maybe I will just ride!!!!
