1 - 2 of 2 Posts
I had removed the carb to clean and after installing the throttle no longer springs back like it did.
The spring that is behind the plate for the throttle cables are you supposed to be able to add tension?
I don't have a carb in front of me, but I remember it was tricky to get on properly.
As I recall, you will need to get the spring in place on the pulley, then turn the pulley to put tension on the spring, then try to slide the tensioned spring-pulley assembly on the throttle plate shaft.
Jb
1 - 2 of 2 Posts
