1 - 13 of 13 Posts
I replaced the OEM Bridgestone front trie with a Shinko 700, just love the tire for the price, good traction on pavement and dirt. My only question is it seems to wear uneven on a slope, more at the back of the threads then in front. Need advise on if the problem could be caused by incorrect tire inflation or improper wheel balancing
It's normal with a lot of tires. You can turn them around and remount them and even them out if you want.
Looks normal to me. At least in the sense that my factory front tire wore the same way.
Tom
Switch your wallet to the other pocket when you ride. Watch wear. When it evens out, remove wallet and ride with out it.
I'm equally poor weather riding with or without my wallet:(
Tom
You are braking to hard with the front wheel. The rear tire doesn't wear that way because braking is counterbalanced with acceleration.
As LT suggested, you can flip the tire over to even out the wear but if you don't change your ways it will just happen again.
Suggestions: When riding on asphalt increase the tire pressure 10 or 15 lbs. above what you run now. I use 30 psi in my front tires. Also, concentrate using the rear brake more, or to a greater degree, than the front. (Of course in an emergency use them both to the max!) Practice stopping with the rear brake only then add in the front brake once you get the feel for what the rear brake only will do. Good luck.
I wore out a couple of Bridgestones before I figured out what was going on. Here is a picture of one.
That front knobby tire wear is caused by sustained high speed pavement riding. In that case it is 50-55 mph on a TW
Discussion Starter #13
Thanks alot, will try this out!!
1 - 13 of 13 Posts
