I'm having a devil of a time getting my ITP Terra Cross bead to seat. Time, repetition, extra lube haven't worked. I'm basically down to my last efforts before I trim the bead. Is there anything else I can try before trimming?
I saw someone mentioned using Astroglide to get the beads to seat. Now, having some experience with Astroglide, I happen to know that you can pretty much make an elephant fit thru a doorjam if you use enough Astroglide, BUT since I ride in some wet conditions, I think it could regain lubricity at an inopportune moment and allow the tire to slip eventually.
Having searched the forum extensively, it seems that the crowd is about 50/50 who's trimmed the bead and who got their ATV tire on without trimming. That being said, no one that I can find has discussed the following:
HOW DO YOU DETERMINE HOW MUCH TO TRIM OFF THE BEAD??? If you trimmed yours, did you take it to the steel belts right off the bat? I was thinking of taking 1/16" all the way around, but I want to make sure it's enough. Comments?
