+1 on the bogus filters out there.
Any squealing or other noises/symptoms before the bike died?
My grand son was riding it and he said it made a bad sweeking sound
Was the oil bleed screw loosened on the top end with the motor running after the oil change to make sure the oil was getting up there?
If no oil comes out with the motor running & that screw almost removed disaster is imminent![]()
I seem to remeber loosening it a little till oil appeared, does it have to really gush out?
Does anyone have any idea what size the bleed screw is? Yesterday I was commuting home and half a country block from my driveway I see smoke blowing out my rear, no pun intended...I looked done and seen that oil was spewing out the top of the cylinder head. I got her home and realized that the oil galley screw/bleed screw backed out and oil leaked everywhere. Lessoned learned torque to specs.....
It should be an M5. M5's usually require a 10mm wrench. Don't forget the seal for underneath the bolt head.
whats the length and is a tappered bolt?
It's not tapered. It sits flush on the head. For sealing, it requires that seal underneath the head of the bolt.
I don't know the length for sure. I'd say about 15mm. They won't be much more than a 20 cent bolt so you could grab a different lengths. Or use a paper clip with a bent tap at the end of it that will fit in the hole and allow you to gauge the distance to the end of the threads, then go a couple mm shorter than that.
I think this is an M6 flange bolt.
Nice catch. M6's take a 10mm wrench!
Back to Jake, the most common reason is the oil filter. Beyond that it's the bleed screw, debris that got in the oil filter housing, debris in the funnel or around the oil fill point, wrong oil or bad luck. If it wasn't maintained prior then it's always a gamble for what the previous owner did or didn't do.
What oil did you and the previous owner use? Modern automotive oils are not suitable for TWs.Thanks guys, this was a used motor so no telling what happened before. Like I said before, oil was full, right filter, pretty sure I bled it, it went prob. 20 miles be fore death, so no telling. Happen to have spare head set up, just wanted to see if there was someing wierd that happens. Jake
