1 - 6 of 6 Posts
What is a good range for a torque wrench for working on our TWs? I have a smallish one suitable for bicycle work already, but need something larger to handle bigger jobs.
I have 2. One for the lower torques (30 to 250 inch pounds) and the other ranges from from 20 to 250 foot lbs.
You almost need two torque wrenches. One in inch-pounds up to at least 250 and one in foot-pounds up to 100 or 150.
I started with beam type wrenches and went to click type but I am leaning back to beam type.
I think the beam type aren't as accurate but left sitting in a drawer for a very long time will be more reliable than a click type. I find after long periods of non use the click type have to be put in a vice and clicked a few times to "loosen up" before it seems to work accurately, or even work at all.
I have three, but only use two for the tw. As follows 40-200in-lbs, 5-75ft-lbs, 50-250ft-lbs. The big one never touches the tw. All three or them are snap on click type. I reset them after every use and have them checked for calibration annually. I see them as a worth while life long investment.
Just checked the range on the bike torque wrench and it is 2 to 20 Nm (about 17.70 to 177.01 in-lbs or about 1.5 to 14.8 ft-lbs). Looks like that should cover the low range. Now just have to decide between a 10-150 ft-lbs 1/2" drive and a 20-200 ft-lbs 1/4" drive torque wrench to cover the bigger jobs.
As mentioned above, the key with the click type wrenches is to reset them to zero before putting the away to keep the spring relaxed when stored. I have two of these, 2-22 Nm, and 5 to 80 ft./lbs. Use both of them on the TW.
1 - 6 of 6 Posts
