521 - 533 of 533 Posts
I notched out my trailer rim to fit the rear hub from @Stufidmotard today. Instead of making a template to guide the hole saw, I decided to use a small tabletop drill press instead. First, I drew a line from the outside edge of the lug holes and marked the center with a punch.
Automotive lighting Automotive tire Hubcap Alloy wheel Brass instrument
The next step was to clamp up the trailer wheel on the press to drill a 1/4" hole through each mark. The hole saw bit I have uses a 1/4" bit for centering so, these holes would serve the purpose of keeping the hole saw from walking.
Kitchen appliance Cookware and bakeware Cooking Cuisine Gas
Liquid Water Drinkware Ingredient Fluid
I used a 1 1/4" hole saw compared to the 1 3/8" that I believe is most commonly used. I did this for no other reason than that the only one I had was 1 1/4" and it seemed to eyeball up just fine. Using moderate pressure on the drill press and LOTS of cutting oil, the holes were drilled with very little effort.
Liquid Solution Fluid Drilling Gas
Water Liquid Fluid Gas Asphalt
Lastly, I knocked all of the sharp corners off the cuts with a Dremel tool and then used a file to finish removing material until the hub fit through nicely. All that's left to do now is finish smoothing all the rough cut edges with a half-moon file before applying some cold-blue solution to the bare metal. And to mount the tire, of course!
Automotive tire Fluid Art Circle Automotive wheel system
Water Tire Automotive tire Wheel Tread
Yes and no! I opened up the trailer wheel enough to pass the hub through, however, it seems that I never acquired the appropriate lug bolts to actually mount the hub, Doh!
Hey Dave, let me know what size lug bolts that you need and I will send you a set of four.
Wow, thank you, Brother! I'll send over a PM.
Merry Christmas to you as well, Brian! Thank you once again!
Thanks again, @TW-Brian for sending me over those lug bolts. I am very grateful! Now all that's left to do is to transfer over the 70T sprocket and install this trailer wheel conversion setup onto the bike!
Oops! There was supposed to be a picture attached to that last post...
Tire Wheel Automotive tire Tread Locking hubs
