Status
Not open for further replies.
1 - 3 of 3 Posts
Am contemplating a TTR/TW hybred.  <br>Mate CJ7Pilot's TTR front suspension, brakes & 21 inch rim with Betty Boop's TW frame & speedo-deive, 223cc 6-sp motor, JoeMama 2" swingarm, Terracross ATV, and a Banshee shock body with TW200 shock spring.<br>Some research &  measuring of parts on hand make this all seem feasible. Each step has been pioneered and proven sucessful by the likes of Lirdbrth, Gerry, Raybar , Ronneydog among others. Just seems once Betty Boop got TTR power it would benefit from the TTR front end if combined with a suitable rear shock & spring. Basically will be chasing the plush suspension on the Mr.Gizmo bike with a blend of Gerry and Lizrbrth ideas. Prep a Banshee shock for compression stops and travel, add a TW rear spring. <img src="https://www.tw200forum.com/forum/attachment.php?attachmentid=190366&stc=1" attachmentid="190366" alt="" id="vbattach_190366" class="previewthumb align_center size_large" style="">.<br><br>These bikes look good with a bit more height, a 21" front rim and ATV rear tire. This is DaveDyno's similar interpretation. <img src="https://www.tw200forum.com/forum/attachment.php?attachmentid=190368&stc=1" attachmentid="190368" alt="" id="vbattach_190368" class="previewthumb align_center size_large" style=""><br><br>Anyone see any obvious flaws?  <br>XT225 speedo cable, TW speedo hub fitting and TTR whee, hub, brake, forks, brake line, master cylinder all seem willing to play with each other.
Discussion Starter #2
Huh?
Don't know what happened above but hope I can build better than I can post.
Prepped Banshee rear shock body by Gerry, this is in the Mr.Gizmo bike but mated with a Vstar based spring. Bansheefunction.jpg
1 - 3 of 3 Posts
Status
