Wondering what tube turns out to be best for an ATV tire mounted on the TW. I know of 4 failures by the stock Bridgestone tube from a split near the valve stem under high pressure while setting the bead. One was mine.
Valve stem needs to be TR-4 or TR-6. Have searched for a tube with those stems in an atv size with no luck so far.
If a stock tube should've failed it should have been mine. I won't go into what pressure or how many times it took.
I'm running the stock tube... just ordered another one since I got the nail in the original one.
Turns out a 12 inch atv tube will stretch over the 14 inch wheel just fine. So that's what I decided to use after the stock tube failure on mine and two others I know of. Kenda makes one.
