1 - 4 of 4 Posts
Hi everyone, my bike`s front turn signals always shine. When I switch on my turn signal, both lights flash, but one flashes brighter than the other. Is this normal or is it maybe a ground fault?
Front turn signals also serve a daytime running lights and are always on. Have you recently altered any of your turn signals? If you have, sometimes you can cause the problem you described. Stay tuned, someone with more knowledge will soon chime in with the fix.
Front turn signals have three wires and a double filament bulb and the rears have two wires and a single filament bulb. Make sure they both have the correct bulbs and number of wires and then make sure the connecting buds in the black rubber boots behind the head light are plugged in to the correct colors.
1 - 4 of 4 Posts
