I'll have to look at my carb more closely, I haven't seen any vents. Unless we're talking about the small drains that come down in front of the swingarm?Nope - works for the slider as well ......
We are - that's the bunny - one of those drains will be the battery breather, the other one is from the carbUnless we're talking about the small drains that come down in front of the swingarm?
Mine has 2 that come out of the carb. Its battery was replaced with a sealed maintenance free one. Should they both just run up under the seat then?We are - that's the bunny - one of those drains will be the battery breather, the other one is from the carb
Stick the tee in where it comes out of the carb, and run the new section up high (seat/bars/tank) ....
Ok thank you, I will try to figure out which is the drain and which is the vent. Also this is not a CV carb, it's a slide carb.All these carbs are different, and I do not have a CV to compare to. Some are air vents, some are drain vents, so to be sure you can tee both - one end goes down as it does now, the other end goes up ....
New member/carb vent mod question
Hello my name's will and I'm a new member of the forum here. I live in butler Pennsylvania and my TW is a 2019 model and mostly stock. I have used this forum a number of times before becoming a member and figured I might as well register myself here. I've got a question about the carb vent...www.tw200forum.com
