1 - 19 of 19 Posts
Hello All,
I'm a new owner of a 2004 TW200 w/1000 miles and this is my first post. Let me say I am not a motorcycle guy. I've owned atv's for a number of years, but atv's are not allowed on forest service trails, thus the reason for my purchase. Anyway, I've read 15 pages of custom/mods and I don't even know where to begin on how to set this bike up. BTW: it is completely stock right now..
I will use it primarily as a hunting rig. So any pictures would be helpful. I need and extra fuel cell; would be nice if I could use the 1 gal Koplin I have mounted on my atv. My bike does have a factory rear rack, but I need to put a good sized lockable tote or something on the back. It would be nice if it could hold a 3000ci back pack along with my tripod/scope. It will be used at elevations of 5000-7500ft, so I'm not sure if a gear change would be necessary. As stated above it will see some trail use, but most of the time it will be on improved roads, two track, or atv trails. Gun and bow mounts will be needed, especially the bow mount. I can sling the gun if absolutely necessary and I don't like my rifle scope being bounced around. Hunting boots will be worn while operating the machine.
Give me your must haves on a hunting rig....
Thanks
It's all about space. Two wheels call for more thought and planning with regard to making best use of it. If you've been an ATV hunter for very long you're used to having buckets of it and lots of acreage to mount your weapons with ease. Guns and bows have to be situated in a manner that not only protects the weapon but isn't a hindrance to operating the bike, and that alone requires some forethought in order for them not to interfere with the best use of space. Putting all your crap on your back will get old after awhile but with some adjustments it really won't be necessary.
You'll gobble up that O.E.M rack immediately with a hard case and have nothing solid on which to attach a scabbard or fuel cells. It's very likely that you'll also exceed the weight limits of the subframe.
Not to brag (much) but I've got the biggest rack of anyone on here
and it still isn't equal to the smallest front rack on some of the smaller quads.
My must haves in your situation would probably start with a more substantial rack than your O.E.M. When it comes to the TW that almost always means a Cyclerack. A bigger rack is key to your other plans and means more space for your game and gear and will ultimately make mounting your Kolpin tanks, gun and bow racks infinitely more doable. By design the rack takes most of the direct stress off the subframe, as well.
Next up for me would be an oversized tank to get the fuel between your knees and off your rack in order to make even more space for game, gear, gun and bow racks, etc.
All the little doodads we've all added can come later but if you wanna get out there right away and carry all your stuff I'd start from the back.
Here's mine. My subframe is triangulated by set of Happy Trails pannier racks, but it's the same principle as the side rails and frame mounts built into the Cyclerack. I somewhat routinely haul 130 lb. "Cali bales" of alfalfa on the rack. The Cyclerack is narrower but probably even stronger:
littledawg, as you may have already figured out for yourself, this lizrdbrth guy knows what he's talking about. You want more fuel, and you want it all in one tank.
The Clarke TW200 specific tank is a little bit bigger and pretty much a straight bolt-on job, but, it really only seems to hold less than a gallon more than the stocker.
The Clarke XT350 tank is a much more committed mod and involves a whole lot more time and energy, but I don't think that any of us who are running an XT350 tank (Clarke or OEM) are anything but thrilled with the painless nature of the extra fuel capacity it offers. It's worth the headache of getting it on there in the first place.
Cycleracks is the way to go too, unless you happen to be very skilled with a welder and can fab up something custom that attaches in a similar way. You can mount pretty much anything you want to a Cycleracks rear rack, including cheapo topcases (lo-pro like used DeWalt cases or big boys like the 8gal Rubbermaid action packer, or whatever soft option you can find at the surplus store) and Kolpin stuff like rifle scabbards, etc.
You can mount that fuel cell you mentioned to the Cycleracks too, but from the sound of things you're gonna want that real estate free for other cargo.
If you're wanting to ride any kind of dirt, a better front tire is going to be your best mod though. The stocker sucks in the dirt. I love my Shinko 244, but there are plenty of options and they're all way better than the godawful death wings Yamaha puts on the front.
">[media]http://__CODEBOX_0__[/media]This was the set up I used for the first time this last hunting season. It seemed to work well enough, although I wasn't using it any of the days I killed deer. The 25mm ammo can mounted on the cyclerack held enough clothes and supplies, and kept my helmet in the dry while I was out hunting.The old style kolpin gun scabbard is mounted to the cyclerack with a 1/2 " nut welded to the rack.
DeerDawg:
Just wondering if you know how DeerDawg did the camo on the plastics? I was thinking about DIY rhino lining but not sure how well it would stick to plastic...
3M. From Camoclad, I think. Only way to go. Way better than paint.
What is the stock rear on a 2004, if there is a difference in years? And how much top end do ya loose?
Stock is 14/50 in the U.S. market. All years.
70T tops out at around 35 mph.
With a 70t on there you should be able to do backflips! BTW, I hate that pic of the deer with it's legs chopped off. I guess I should stay away from the hunting threads...
Haybinder accident. Ronny was just giving him a ride.
Scabard and Bow Mount
Hello All,
Thanks
Howdy, They have hard plastic scabbards with fleece inside for four wheelers. I found just the bottom in a junk pile. It had a carry handle and several large holes for mounting. I mounted it on the left turn signal bracket. By removing the lens cover the opening in the handle fits over the signal and hangs down below it. Then you replace the lens cover which keeps it from coming off. The bottom of the scabbard angles down and forward and ty wraps behind your heel on the footpeg. Also you want to drill several quarter inch holes in the bottom to drain any water that might get in. I use it with my scoped rifle, lyman flintlock, beretta suprema shotgun etc. I often leave it on for a walking stick and a grabber to pick things off the ground without getting off. You can also get mounting brackets for your compound bow by buying mounting brackets for you handlebar mounted windshield. Instead of a windshield you can mount your bow string forward like long horns through holes in your risers my adjusting the uprights. You have to be xtra cautious with width. I have a matthews ovation and it worked well for me and that's a fairly wide bow. Hope this gets you started. Wen
I've been working on a bracket to mount my new gun boot on the front forks and should have it done today.I will try and post some pictures when it's done.This site has been a great help so thanks everyone.
All I see is deer steaks and gravy.
1 - 19 of 19 Posts
