My Baby Tdubs was surging terribly at specific throttle position (anout 1/3 to 1/2) unless really hot, so I sprayed some carb cleaner on the outside for diagnostics and boom! The revs change! Turned out to be loose throttle shaft causing air leak a. I already have a new carb on order (turns out to be cheaper - 70$ vs 200$ - than sending it to a specialized company which will machine new bushings etx) but is there a way to fix it temporarily by adjusting the mixture etc? I turned the pilot screw out about 2 turns from lightly seated but it helped only a little bit. Thanks for answers in advance
