1 - 20 of 21 Posts
Hey guys, new here and new to TWs in general. Today i had a new issue. When i got on the bike and started it and set out it was hard to get into second. Then the shift lever didnt return down from the up position. It was stuck and had to be forced back down to get into 3rd. And it was worse as i went up in gears. And its stuck hard and needs to be shifted hard to be brought up and only while moving will it work. Any ideas?
Is the shifter bent and rubbing and hanging up on the case? That's happened to me. Have you changed the oil recently? If not, start there.
I just bought the bike off a guy. Although he said he just changed the oil he might have been lying. Oil level does look good tho. The lever doesnt look significantly bent but honestly i wouldnt know better. Nothing happened though between today and yesterday tho to bend the lever
Check your oil level. Is the clutch fully engaging? It should roll easily in neutral as well as in gear forward and back with the clutch lever pulled in and engine off or on. If the cable isn't adjusted right or somehow got off it's routing, that might cause difficult shifts. Maybe the clutch springs have gotten weak. I changed mine out to these;
I've found Rotella 10-30 conventional oil to make the smoothest shifts for my TW200. Snickity Click! Easy Peasy to find neutral at any speed including idle or engine off.
Yeah so i suppose i should mention it slides into neutral and first with ease. Shifting up is the only issue.
Hmmm... almost sounds like a bent shifting fork. I've never torn down to the tranny on a TW200, but I have other bikes. All were 2-strokes so fairly easy. I've never heard of anyone bending a shift fork on a TW200 though. Might try the search feature to see if there's any history.
TWs are cold blooded. You need to let the engine warm the oil up. Also remember to only use oil designed for a wet clutch. You may just want to do an oil change. Lots of idiots out there.
Here's a search for shift fork issues;
Shift Fork Issues
I'd make sure the shifter lever bolt isn't backed out and blocking against the case before panicing.
Reactions: admiral
Discussion Starter #10
I may have been a bit rough with the shifter i had a klr before and you had to hit the shift fairly hard. Any advise for someone that never pulled open the transfer case?
Discussion Starter #12
I'm honestly thinking of taking it to a mechanic for a diagnosis. Any one know how much that usually costs?
If your mechanically inclined, drain oil and pull the clutch cover. Below resides under your clutch basket. Check spring number 2 and the the fingers that rotate the shift drum and see if anything is suspect in this area before going deeper into the engine. Check number 7 and 4. The star is what the fingers index to change gears. Most shift related issues are in these areas. Shift forks and drums are inside the center cases and can usually take quite a bit of abuse before failure.
207438
207437
Discussion Starter #14
Thanks man! Ill pull out the oil pan in a couple of days and check it out! I'll let you guys know what i find
Discussion Starter #15
Your welcome. Check that your shift lever is not spinning around on the splines before you do anything. I've seen some that ran loose for so long that the splines were almost worn smooth.
keep it simple and check the most obvious first. be sure that the shift lever and shaft move freely before moving to more complex tear down.
Reactions: Fred
Discussion Starter #18
To the guy that recommended i just loosen the shift lever bolt: thank you so much! I can finally get back on the saddle for some adventures!
So that was it?!
Great!
At least 3 of us mentioned it. Guess experience ran strong with that is an issue.
Glad to hear you got 'er done!
Congratulations!
I was going to suggest double checking the obvious external issues like putting bike on simple stand and run through the gears with hand on shifter, not foot, looking and feeling for any conflict in shifter movement.
Experience teaches that occasionally while riding we can also hit things that bend the shifter in so that it hits skid plate or case cover.
Sometimes a bit of a boo-boo can bend some of the other parts a little bit too.
1 - 20 of 21 Posts
