1 - 10 of 10 Posts
Stock grips caused numb hands, especially the right where I cut off half my thumb, so wrapped with short lengths of standard foam pipe insulation. The 3/4: ID PVC was the perfect size; self stick edges are holding fast.
Used the 1/2" ID PVC size on the Cyclerack
Harbor Freight welding rod tubes zip tied to underside with plastic snap-hooks to secure caps
1-1/2" memory foam car seat cushion from Walmart, held on with 1" nylon straps for now but will be sewing Velcro tabs. The underside is vinyl and does not slip on the stock seat; the top is a breathable mesh.
My dogs are not as agile as Georgie and would be coyote lunch afoot. The love the wind in their faces so I put them in a pet carrier with extra large holes. A couple of cleats on the bottom keeps it centered on the Cyclerack and turn-bolts hold it tight.
Nice. I love cheap improvements. The welding rod tubes look like TW sized JATO devices.
Looks like a great way to train them to ride like Georgie. In time, go to an open top crate, then a flat slab, etc, little by little. Just don't go nuts and spook them in the beginning......:)
That foam is a nice quick fix but the only problem is that it doesn't last very long - it doesn't stand up to the UV in the sunlight and it gets dried out and brittle over time. But it's cheap and easily replaced.
:DThis is why I love this forum! On my daily 44 mile commute (mostly freeway) I have been fighting numb hands, arms and even shoulders. I've been on the verge of getting new grips, rubber mounting my Acerbis gards, filling my handlebars, or even getting the little cruise assist thingy for the throttle. But I have not the time or energy right now, so when I saw M C Toyers foam on the grips I ran down to the shed and in ten minutes I have foam neatly attached with Gorilla tape. They feel soooo goood! The foam I had was a size too small and was not the self stick type but I neatly cut a wedge to fill the Gap and used strips of Gorilla Tape to hold it all in place. Actually looks kinda cool and should out last un-taped foam. FYI my wife's nice serrated bread knife worked super for cutting the foam and tape, heh, heh. I can hardly wait for the ride to work in the morning, I know it will be way more better! Many Thanks to M C Toyer!;)
Best regards, MAC
That can be fixed by wrapping the foam with tennis racket handle tape. I've done this to my scooter grips and it works great. The tape comes in a variety of colors, is inexpensive, and easy to use.
Here's some links:
A handy trick I learned about cutting foam rubber is to use an old electric knife from Goodwill or similar. Goes through any kind of foam rubber like a, well, knife through butter. Cuts totally straight, too.
cnc200
1 - 10 of 10 Posts
