So I've been searching for my solution to my electrical issue and am now stumped. So my issue began about 3-4 weeks after a new TruGel battery was purchased. One afternoon (after riding it to work in the morning) the lights went dim and would get more dim as I gave it more throttle/used turn signals/brake light. Fortunate for me, it is a '99 and it has the kick start so I'm still able to start and ride it all day with no issues other than no electric start and very dim headlight/brake light/turn signals. So after going through the diagnostics for the charging system in the user manual, I arrived at the bottom of the flow chart, either a bad rectifier/regulator or wiring is bad. I got a new rectifier/regulator and it is not the solution. My ground contact is clean and very good.
Here's my voltage measurements on a freshly trickle charged battery:
Key turned off: 12.2/.4 volts
key turned on, engine off: 65 millivolts
bike running at idle: 12.8-12.9 volts
roll on throttle: ~9-10 volts (depending on how hard I roll on it).
I'm no electrician, but this would lead me to believe I have a short somewhere in a non-vital system since the bike runs after being kick started (correct me if I'm wrong please). Last night I tried to find the wiring issue. I started unplugging things then turning the key to rule out each individual system as not being the short. Before I knew it, I unplugged every single wire/system that I could find (consulting the wiring diagram, I'm nearly positive I got everything) and still got the same ultra low voltage once the key was turned from off to on. So I took apart the ingnition module, turned out there was a little corrosion on the contacts. I sprayed it down with cleaner and got it nice and shinny again, put a little dielectric grease on the contacts and re-assembled. STILL same thing. No power once the key is turned on. I did not pull the gas tank off and disect the wiring harness under there. Oh and I checked my fuse, it's good, both visual and voltmeter inspection.
So, does any one have any ideas before I disect the wiring harness? I'm considering taking it to a dealership, but I would prefer not to.
Thank you!
Dale
Thank you!
Dale
