But you adjusted I assume? Adapted to the shifting given the spacing?Yes, they do. Particularly with MX boots.
Thanks may stick with stockers until yours are on market and/or someone actually rolls with your thought which makes total sense and one of the most needed cheap mod, yet not there with perfection with aftermarket.I adapted. The pegs are worth the inconvenience. My feet aren't quite as big as yours (10.5) but the TW has a pretty short shifter as it is, so they definitely affect shifting.
I'll probably weld up my own one day, with all the offset toward the rear. You could probably tack another stocker to the back of the existing pegs, er sumpin'.
For some reason Yamaha saw fit to put the left footpeg further forward than the right. Correct that situation somehow and the wider pegs would be less of an issue.
Non the less thanks for responding!
I was wonder how much more they stick out from the bike than the stock ones?
That is the D2Motto pegs.
Do D2Motto have only one size?
