OEM parts? How many miles on chain and sprockets? Length of 30 or so links stretched out with a good 10 lbs. pulling force?
Just an observation from the pictures as best as I can see. The rear sprocket looks to be in decent condition while the front IMO is not. The fact that you will get the chain with both sprockets and all three are worn together is OK but I would not use that front sprocket with a new chain at all. The basic work necessary to change both sprockets and the chain makes the installation of these used parts a rather senseless procedure IMO. Chains and sprockets should always wear together so when I do it I always do all three at the same time.
