Mine has a little buzz but not bad at all. I’ve never had it cause my hands to go numb. It’s possible vibration can be from out-of-round or unbalanced tires, not necessarily just from the engine. If you think it is from the engine, it wouldn’t hurt to make sure your engine mounting fasteners are all there & torqued.My tw200 vibrates horribly both in the handle bars and the pegs. It gets worse when you go faster then 45 mph on the road. It is a very bad vibration and after a 20 minute ride my hand fells numb. Are there any solutions that help?
First, have a knowledgeable Yamaha person check out your MC. Parts Unlimited sells foam grips for $5.00 to $10.00. Use old-type hair spray without alcohol to install over the stock grips. Let dry overnight. Allow a few hours to a day to get used to the larger grips which are definitely better for Carpal Tunnel. If after a day you don't like them they can be easily removed. Be sure to install a Sound Off Recreational Vista Cruise Throttle Clamp first, from Amazon for $28.49, you may need to drill a hole in it for a tie wire, to hold it from rotating depending on your throttle.My tw200 vibrates horribly both in the handle bars and the pegs. It gets worse when you go faster then 45 mph on the road. It is a very bad vibration and after a 20 minute ride my hand fells numb. Are there any solutions that help?
