1 - 18 of 18 Posts
At any speed over 50 mph, I get some pretty good vibrations in my handle bar grips. Also, the front tire starts "humming" pretty loud at those speeds also, it makes since that that could be part of the vibrations. Any body change from the original front tire to a different style tire that doesn't sing notice less vibrations? I dont ride off road much, just grass pastures on my farm.
A front tire change should help, but I'll let those with non-stock tires weigh in on that.
Some members have filled the handle bars with silicon (get a tube at Home Depot, etc., lay the bike over and start squeezing it out a caulk gun. Turn bike to other side and repeat if nesiciary) and have commented on a noticeable decrease in vibrations. Since its a $3 fix it might be worth a shot. Thicker 'squishier' grips also help, check out the set ProCycle has on their TW page. I find my leather riding gloves (crotch rocket racing style) help a lot to reduce felt vibes and improve comfort.
I'm going to order some different grips tonight and try the silicone later this week. Turning 50 this year, some things bother me more than they used to, such as vibrations in my already sore hands.
It sounds like the front tire is baddly cupped causing nasty vibes............. I change over to a street tire on the front and all has been smooth for 7,000 miles....Also what gearing are you running ??????? I also switched to a 14/47 combo at the same time... So I'm guessing both helped my vibe problems. OMM.
The handlebar vibrations on my 04 were killing me. Already had some nerve damage from logging (running a saw). I bought the heavy walled aluminum ATV bars. I bought the Pro Grip 714 grips. I changed to the Shinko 244 front tire. It all helped incrementally, but the vibes were still bad. This forum had suggested lead shot in the bar ends. Finally I got some small lead shot. Stuffed some foam down the bars to just past the 1st bend. Filled the bar ends with shot, tapped them to settle it, added more, finally kind of packed it in with a punch and a hammer. HUGE DIFFERENCE. More recently I added Ride-on balance & seal to both tires, made a significant difference in vibes again. Cheap lead shot made the bike good at highway speeds.
Roy
I'll be turning 62 shortly and both my rear end and hands feel the vibes and are numb after 20-30 miles. I changed the rear to a 47T and I do get a bit less vibration but at a cost of some low end torque. The 14/50 stock combo is probably the best but for mostly road and hard packed trails the step down to a rear 47 might help. I am keeping it but it is not a major fix or even a big benefit as far as I am concerned. Changing the gearing is a tricky and very personal thing. Some love it while others hate it.
As for the silicone in the bars I think I would refrain from that and go a different route at first. Once you fill the bars with silicone there is no going back!
Go to your local Gander or gun shop and get some lead shot for reloading shotgun shells # 7-9. Stuff a wine bottle cork in the throttle end about an inch. From the clutch side fill the tube with the shot and plug it with cork and see if this helps. You can always dump it and try the silicone next. Lead should deaden the bars pretty well. A road worthy front tire could also help if you don't go off road much.
I am still experimenting with the seat. Some said the sterns/ Coleman ATV seat cushion helps and I have it. Help, yes, great No. Some say the Seat Concepts is the way to go while others swear by the Airhawk adjustable small pillion is the best. I'll let you know about the Airhawk when I get one. I can live with the Coleman cushion but it sure would be nice to have a comfy seat for this ass.
If I go 50 miles it takes a half an hour before I can feel my fingers or fart with any pleasure but I do love my bike and I am working on the fix.
While on a ride earlier this year with the NorCal crew I experienced mucho vibration that caused my fingers to tingle during the ride and for several days later. I researched this problem on this site as well as the Adventure Riders site. I had to do something! I filled my bars with silicon caulk. I didn't know what to expect but thought what the heck, I had to do something. I am very satisfied with the results. The next long ride was comfortable. No more tingles! If you give it a try and have the same results you will be happy. Good luck.
Joe
I use a pair of gloves I got from Home Depot which have some extra padding the palms. These are slightly insulated gloves made more for fall or winter, but I use them for riding year round. The little tag on the gloves reads "Blizzard". Didn't cost to much either.
With the gloves on, it lessens the tingling in my fingers, hands, or arms like I use to feel.
To be honest the only thing that I find vibrates a lot on my 08 is the foot pegs. It has helped that I switched to DMO pegs. But still if there's one thing that's going to go numb its my feet.
I also have horrible ankles/knees from years of wheelie boarding so that cant help.
Sent from my HTC One using Tapatalk 4
Discussion Starter #10
Got to love Gary. After you turn 50 you never trust a fart, whether riding or not. AS far as sprockets, I think I have a 15 on the front and 50 on the rear. Im going to try a 47 on the rear and a new front tire. Mines the origional with 2800 miles.When I ride standing up and watch the front tire, I can see the tread not running true.
Stock sprockets on my bike were 14/50. I changed the rear to 47 and left the 14 front and so far it is fine. I lost some low end torque and gained a few MPH on the top end with a little lower RPM at the sweet spot of 50-55. It works for my rides but I do notice I cannot chug along on gravel like it did before and the clutch has to work a bit harder. Going up and down the mountains is fine if you plan ahead and maintain your head of steam. I do not think the bike would perform all that well with even a little higher gearing such as the 15/47.
Careful with them farts, sneaky little lumpy bastards:icon_biggrin:
Reactions: Dubzha
Rocky, Sorry for my poor spelling. Silicone caulk is a product used to fill gaps and can be purchased at any hardware store. I took both grips off and filled from the left side all the way through. I made sure not to let any come out the right side and not gum up the throttle tube. It really is a easy and cheap way to address the bar vibrations. Hope this helps and good luck,
Joe
My issue with shot is you are adding weight which messes with the power to weight ratio (and let's be honest the TW doesn't have power to spare) and you are also changing the balance of the bike by adding weight to the handle bars (way up front and way high up). It's probably just my anal retentive ness and years of racing speaking because I know we are talking about ounces but silicon caulk is barely grams. However yes, shot is very very easy to remove, caulk not so much get new bars don't even try. Personally I don't do either for both those issues. Good gloves ($$$ but already had anyways) and good grips do enough for me. TW stock grips with no gloves aren't something I'm really willing to do for too long. (Shot suspended in silicon, hmmmmm)
Soon I plan on swapping to the SR241 (road noise and sand control mainly) but I know that will also help with the vibes so that is a plus. The thing is this is a thumper, it will always vibrate. Accept that and try to get it to a manageable level or move on to/also get a balanced V-Twin or I4. Hopefully you can get it to your comfort level and enjoy riding it, just be realistic about what it is and isn't and good luck. Let us know what works and doesn't that you try and don't be afraid to keep asking questions here, that's the point of a forum.
I wouldn't complain about the vibrations in my handlebars. I might have just gotten a peach in that sense. Although right off the bat I had put new grips on there.
Although when leaning through corners I did notice the buzzing from the off set side treads in the stock tire. With the 241 on there now that is gone. Really liking the 241 after whipping around on it today.
Sent from my Nexus 7 using Tapatalk 4
I added less than 3 pounds of shot today and filled them full and it took all of 5 minutes. Don't really care about front end weight and would like more for when I load up the rear rack with 60+ pounds and the front wheel wants to do wheelies.
Rode for about 60 miles today with the loaded bars and it does help a lot. If the silicone works then go for it, I can't see why it would ever need to be removed anyway.
Now for the balance thing, at 62 I don't have much of that either so a few pounds here or there won't make much difference at all. They say the Cyclerack rack is good for pulling deer out of the woods. I am sure it is strong enough but you will want to be sitting over the bars to do it with 150 pounds hanging over the tail end.
"If I go 50 miles it takes a half an hour before I can feel my fingers or fart with any pleasure but I do love my bike and I am working on the fix."
Good one, GaryL!
1 - 18 of 18 Posts
