121 - 122 of 122 Posts
They say they can but that is not what I read in this:
"Will the SH calibrate both my speedo and odometer?
Yes, but it is not possible to calibrate them separately, as one speed signal drives both the speedometer and the odometer.
On most bikes, if the speedo is calibrated to be 100% accurate, the odo will register slightly less miles. While this can be annoying in certain situations, one can always calculate the real distance easily after a long trip.
Alternatively, of course, you can get the factory default indications regardless of the used gearing: accurate odometer and slightly optimistic speedo."
So I take it that you have one or the other accurate
Hmm,I think they should have stated this at the main description,not hidden in FAQs.Sneaky:angry5:
Discussion Starter #122
I received my new front tire from Gnarly Parts today; Motoz Tractionator Adventure. It is the matching tire for the rear. The front Heidenau has seen over 30 000 km.
203186
203187
I also changed the oil and plan on changing the air filter and spark plugs.
Last week installed real hand guards on the bike. The ones that came with the bike were just plastic.
203188
203189
