You are correct. However you can erase/delete the text or picture that you do not want posted, then in the "mispost" you can write something like "Sorry duplicate post". So in your situation, that could all have been done on your first post without needing a second post to explain your 'mistake'. Remember, you can go back into your old posts and change things using the "edit" option. Gerry
In one of my older post's, I was able to change the topic title, if you are the author. By using the edit button, then use the "full editor". At the top of the post I was then able to change the topic title and sub-title, as well as adding, removing, or changing items within my post, as mrgizmow mentions.
However, I don't think you can remove or delete the whole post.
Hope this helps.
I couldn't figure out how to edit or change the spelling in the topic. Nothing seemed to let me do that. And there's no way to delete the whole post even if you try immediately before anyone else views it. Anyway that can be fixed or once you post on here it's there forever?
