Today I went for a quick trip to the store. My blinker light in the instrument console has been burned out forever. Before leaving the store I put the bike in neutral and no green light for neutral.
I figured that the neutral light probably burned out. I also noticed that the blinkers didn't seem to work at this point. I took off, the gas valve on and nowhere near reserve level. While I was cutting the corner my bike died.
I pulled into the parking. As I put the bike in reserve, even though the gas tank is full, I checked everything out. I turned the key off and on a couple of times then the neutral light come back on. Then I checked the blinkers that were now working. Then the bike started up and everything was fine.
What happened previous to all of this is that I had honked the horn. On my Shadow, honking the horn has blown the fuse a couple of times especially when honking and the blinkers flashing at the same time.
I am thinking of hooking up a small capictor to hold a bit of surge to help honk the horn when needed. A solenoid seems a bit much to me for an occasional beep beep.
Any advice?
Any advice?
