1 - 10 of 10 Posts
Going to remove and clean out and replace seals on forks. What brand ATF do you use for the oil? thanks in advance .
I use a simple Dextron II ATF to flush and clean, then fill with a 10w BelRay fork oil.
15 in mine, because I'm fat. :D
I added just a wee bit more oil than Rocky...128mm from the top...not 'cause it was chosen by multiple trial and error adjustments, more like I tried it and it seems to work generating improved rebound dampening compared to stock.:p Got lazy, said "Good enough" and just rode it grinning with satisfaction.
Fork oil level?
Not interesting for me.
I buy a 0,5 l bottle and fill ~250 ml per every side -> both sides with the same hight.
This isn't a high performance front fork, 1...4 mm more or less doesn't play a role. Just 0,5l for the complete system and it will work fine.
It's not a rocket, it just a tdub.
1 - 10 of 10 Posts
