Is that blemish/defect really noticeable or is it under the tank and more of a mindset knowing it’s there type deal, I ask because I see picks of the tank mounted and I don’t notice it but then there are pics which seem to be by where the petcock mount is and that appears to be where the defect is, I’m thinking of going with a white tank.Love the Clarke tank. Got it after putting 1.856 gallons into my 1.8 gallon OEM tank after a casual ride with some friends in the desert. Stock was ok for Play but range anxiety kicked in when in Explore mode. Range isn't a concern anymore and it's rather freeing.
The defect is on the 2.7 gallon TW tank and varies in severity. I believe it's toward the front near the forks. Some people find it completely unacceptable and some just live with it. Clarke discounts the TW because of the flaw.Is that blemish/defect really noticeable or is it under the tank and more of a mindset knowing it’s there type deal, I ask because I see picks of the tank mounted and I don’t notice it but then there are pics which seem to be by where the petcock mount is and that appears to be where the defect is, I’m thinking of going with a white tank.
Maybe you need to put a fuel tap into the lower section on both sides of the tank with a flow valve. Then you would have tripple reserve. One reserve on your normal petcock, one on the left lower side and one on the right lower side. Just flip one lever at a time.It's even worse or maybe better, with a 4.1 gallon Clarke tank. After installation I wanted to mark the level in gallon increments. I dumped in the first gallon and it almost didn't show on one side. I had to shake the bike from side to side to evenly distribute the gas across the hump. That can leave you with 1/2 or even 3/4 of a gallon reserve reserve.
Pred, the issue is with the parasitic drain that you had with the battery monitor. Unless your battery has a battery management system onboard a discharge from a parasitic drain can indeed damage it and those types of accessories should be a avoided or on a switched circuit. This really holds true for any battery, a parasitic drain will eventually damage a lead acid or AGM as well.Don’t buy Lithium-ion batteries. They work ok until they completed discharge then they won’t take a charge. I had bought a small voltage monitor and it drained the battery. POS now I have to buy another battery. They also won’t crank your bike when it’s cold out. I had to crank wait, crank wait, crank wait, ...until the battery finally warmed up enough to crank the motor fast enough to start it.
There will be a test at the end after you read all 6, 208 (and counting) posts, so try to soak it all in as best you can.Wow. 311 pages. 6206 posts. I've got alot of reading to go back and take care of. This evening I pulled the stock chain off and installed a DID X Ring chain. So easy a caveman could do that! 30 miles on the orig., So I figured it was a sound investment to change it now lessen my maintenance.
I had better get cracken.....There will be a test at the end after you read all 6, 208 (and counting) posts, so try to soak it all in as best you can.
Is that your mounts are Fred’sStill no riding for reddave... I can happily say, however, that I did do something with my TW today - installed the IMS pegs. I also switched out my peg mounts with replacements I sourced from Ebay a while back. I was planning ahead for new pegs. As you can see, my mounts were really busted up.
So now, not only do I have myself some nice wide IMS pegs - but they fold up properly like a foot peg is supposed to. Hopefully, I don't beat the hell out of these giants this summer!
Think Dave is getting to be more of an animal than I am.![]()
Seeing your hammer there made me think that Admiral should make him a set of footpegs out of a couple of hammers.Still no riding for reddave... I can happily say, however, that I did do something with my TW today - installed the IMS pegs. I also switched out my peg mounts with replacements I sourced from Ebay a while back. I was planning ahead for new pegs. As you can see, my mounts were really busted up.
Those were, in fact, strategically placed "Admiral in mind" hammers!Seeing your hammer there made me think that Admiral should make him a set of footpegs out of a couple of hammers.
