Hey you and teedubs should get together. His neutral switch/starting system is giving him fits here. Sounds like the neutral switch is going to me. Either that or there is a short on one side of that relay. I think the relay is working fine, if I remember correctly they are supposed to click when activated.
When your bike dies after the light flickers off will it start back up when you hold in the clutch? If your bike no longer knows its in neutral it will kill the engine without the clutch in and kickstand up. Next time it does it try eliminating both and see if it fires right back up.
I would try push starting the bike and see if it will run..That is after seeing if the battery has a charge.My issue is I can't get the bike to start.... Absolutely nothing happens when I click the starter........ I know the bike has to think its in neutral to engage the starter...... But if you jump the solenoid you should still get spark and the bike should still run even if the neutral switch is bad (bike has to run when it's in gear right?)
My bike might be fubar because I don't get a spark when I jump the solenoid... I don't even get a neutral light at all![]()
Of course I'm not there but a faint glow or flicker or what you describe sounds like a bad/loose ground. It could even be a loose battery cable condition. Like above, it's nice to start with a good battery charge.Thanks for your replies so far guys. I tried the tapping of the solenoid, among other areas too. I have been tugging on this wire and that wire, but I can't reproduce the neutral light going out. It doesn't get dimmer nor does it get brighter...it just flickers quickly and goes out...then comes back on 1. when you gently jiggle the gearshift lever(sometimes) or 2. whenever it feels like. The weird thing to me is that even when the neutral light flickers out, the bike sometimes won't die. It just keeps running as if nothing else happened. Nothing really follows a consistent pattern either, sometimes it will die, sometimes not.
I think I'll just replace the neutral switch because that sounds easy and reasonably priced enough. I'll keep you guys posted, thanks again.
