1 - 11 of 11 Posts
Hi! I'm new to this forum and have just started rebuilding my tw125. Engine god a broken rockerarm, a timing chain that has fallen of the lower sprocket and it was in best case 1dl of oil in the engine. Are now rebuilding the top and need a new camshaft and is wondering if this will fit, see attachment.
Will probably as a lot in the near future so bear with me:geek:
Welcome to the board .....
But do I need to take off the bearing that's on it now, the tw125 has only bearing at the outside of the shaft, is'n that right?
That doesn't look the same to me at all. Isn't the TW125 head the same as the TW200 head?
I wonder if a TW200 cam would be a better fit?
The TTR125 looks like it uses a completely different engine.
Hello,
The camshafts of TW 125-200-225 & XT125-200 have the same dimensions, they can be installed in a cylinder head of the TW125
205726
205727
1 - 11 of 11 Posts
