1 - 10 of 10 Posts
Howdy all,
I am looking for a round headlight for my 2012 TW.
Any help would be very much appreciated.
Thanks
Mine came with the H4 plug. Literally plug and play
Reactions: TWBigBlake
I would honestly wire on an H4 plug if yours doesn't have one, it's cheap and easy, just touch brown (usually ground) to the headlight ground wire (prob green) then just use the other two wires to touch leads and figure out what is the high beam and low beam wires. Tag or write wiring down in owners manual/service manual. Proceed with new headlight enjoyment.
Thank you ,I got the headlight working. Now the turn signals come on in front but wont flash. The rear dont come on at all!
On the standard American system, the front flasher bulbs have an additional element that is constantly on, and acts as forward running lights. So what you are looking at, is most likely power loss to the flasher unit, either via the indicator switch, or at the flasher unit itself …….
1 - 10 of 10 Posts
