1 - 20 of 25 Posts
I know an X forum member had tried to do this conversion and he said the output shaft was the main hold up
Now that I know how to overcome that I wonder if this 31.5 HP Brute could be installed w/o changing the axis of the earth
they are FI so it may be easier to run a carb although I'd go for the FI if it could be done
I have heard these can be turboed to get 100 HP but I bet it has a nice bottom end and mid range for mud slinging with a big ATV rear tire
Just eyeballing it, I would think the major hold-up would be the height of the motor. I wonder if (similar to BW conversions) it wouldn't be easier to mate wide triples and swingarm to the larger displacement host frame? But I understand that for those who have a stockpile of TW parts its not as attractive.
With those semi-bare motors only being around $1000 shipped, seem the cost isn't too bad for what you could theoretically get out of it. What would be neat is if someone would figure out what would fit and design a bracket mounting package like they have to put the CB300 motors in the Groms...
I plan to buy a wrecked parts bike so I'll have all the parts to fit and tinker with
the guy I knew claimed he made it fit with little problem
he also claimed Yamaha approached him and paid him to shelve the idea saying they had something similar in the works but that was a few years ago and I never saw any concrete evidence the story was true
I know my BW350's seem to have insane power so that would be a great TW swap too unless the heavy weight makes the TW handle even clunkier than it already does
These big motors might be good for road riding only
Hahaha I think I'm remembering the member of whom you speak. Did he have a habit of making other rather large claims with a mysterious lack of ability to show proof in the form of pictures?
My phone won't let me copy the link, but of you search for "WR250R motor" on eBay there is currently one listed for $1666 shipped with everything from the throttle to the ecu to make it run. I think that would be a much better fit size wise and supposedly has the about the same power.
I really think fabricating pieces to bolt in that would more or less convert the TW from a stressed member to twin cradle setup would be the way to go, and $1666 seems cheap for what you are getting--especially with it only having ~6500 miles on it.
You have to wonder how the TW chassis & suspension would handle the significant gain in weight & power?
I fear the stock suspension is already the weak link in the TW.
One of my TWs features longer fork and shock travel and is so much better off-toad at speed. Riding buddies who have upgraded from TWs to 250cc machines have really pushed up the trail speeds beyond what is safe for the other bike, the semi-stock Betty Boop.
Thus Darth makes a very good point.
ProCycle springs front and rear will definitely be in order and it is fully possible it will be too much for off road but maybe scrambler logging roads etc might be fun
I'll weigh the motor and see just how much weight we are talking if it's only say 20 lbs I just won't doll it up with racks and other accessories like I normally would lol
Yes I look at my YZ450 motor and dream of shoehorning that bay in but it would not be suitable for the TW style of low end riding
Like someone's lady once said "Six inches just isn't enough".
Amazing what three more inches of travel will do to raise the minimum safe speed in the hack, whoops, surprise cross trail ruts, etc. on a TW200.
Stiffer springs aren't the answer in my experience compared to the benefits of longer travel.
Discussion Starter #11
and nobody said they were...
Yes!
Who sez you can't make a TW into something it's not?
Discussion Starter #15
great idea for a skid plate it would be sturdy as hell but there is no natural tie in on the rear of the TW frame although point could be made and I'm not convinced this makes the frame any stronger or more rigid than the stressed motor already does
My goal is more bottom end because to me top speed for the TW is 45 to 50 mph anything more and I'd buy a different bike
At lower speeds the frame is fine and the forks are semi tolerable with upgraded springs
The OEM front springs are barely sufficient the the weight of the bike and an 80 lb rider so they need to be upgraded regardless of motor size orHP
Hello,
You're right,
The TW was made as a motorcycle with bigwheels touring,
The TW125 its speed Max is 64 mph (103 km/h)
At my idea :) I see this like that
The rear attachment would be to make on the bottom engine mount point on the M8 bolt..
I seem to remember that someone popped on here once who achieved this by welding bits of the SR400 frame to the TW frame - complete with pics to back it up. The whole process was complicated, but with a lot of fabrication skills and a significant cash injection he did achieve it
The performance wasn't an issue - it was just something he wanted to do
Try as I might, I simply can't find the link though - I seem to remember he made the cut just before the head stock, then welded the 400 head stock and down tube onto the TW frame
That skid plate mod looks interesting - I for one will be watching with interest .........
Hello, this mounting Engine XT250 on TW....:rolleyes:
1 - 20 of 25 Posts
