Yes I know top speed has been discussed much here. It is not a highway bike. I have a condition which makes me unable to refrain from pushing the limits however.
Also, I thought it was interesting how good the performance of my 2025 TW200 has been! Worth sharing perhaps.
A large percentage of the miles I put on my bike are highway. Posted speed limit is 70mph in my area. Surprisingly, my TW does pretty well! Highest GPS speed I have seen was 77mph, which totally pegs out the factory speedometer (see video below). I can very confidently cruise at 65mph, and regularly hit 70+mph (gps). I even occasionally pass in the left lane on the highway.
As far as performance mods, all I have done is install the Bradley Performance oil cooler, and swap the front 14 tooth sprocket for a 15 tooth. Carburetor is totally untouched. I typically run 93 octane, E10 fuel. I haven't noticed any difference when running 87 octane.
Another thing that surprised me: despite a very large percentage of my miles being literally wide-open-throttle highway miles, with the engine turning 8000-8800 rpm for 70 or 80 miles at a time, the engine is doing very well. Hopefully I didn't jinx it just now. I checked valve lash at 600 miles per the manual, and it was perfectly in spec. I checked again at about 1700 miles, and still it is right in spec.
I have changed the oil 4 times since I have owned it. Always with full synthetic.
The only actual problem I have so far detected by my highway cruising and high-rpm max-power operation is that the buzzing vibrations keep burning out my dash-lights. The tungsten gets twisted up or detached from it's support wires and it burns out. Replaced 3 of them so far with OEMs. I will try some from an industrial supplier I frequent to see if they do any better. If not, I will pursue LEDs.
If it ever blows up, I will of course let you all know.
