In response to the questions in email about Tdub2:
Tdub2 uses all the XT225 trans, shifter, clutch, crank, etc., with the only non-XT parts in the bottom end being the TW countershaft turned to match the XT profile, the TW left side cover, flywheel, and electrical coils, the TW balancer, the TW oil pump, the TW kick starter lever, and the TW cases bored to fit the over-size liner. The XT crank was welded and redrilled, uses a Suzuki connecting rod and a Honda piston with the valve reliefs ground to clear and some of the skirt ground off. Doing a 6-speed, 5-disc clutch, and kick start really isn't that big a deal--other than the countershaft, it's a bolt-in. Doing 267cc is a heck of a lot more work, don't ask what the rod and piston came from, I picked them out of a pile at a wrecker and he ordered matching new replacements for me. A 250cc TW is easy--just use a XT225 or TT-R 225 or 230 crank and a religned cylinder in a bored case, and it's pretty much a bolt-on using xr100.com parts. Oh, and money. Lots and lots of money. I have over $7k in Tdub2 just in parts, not counting the cost of the bike, and all the welding and machine work was free since I have access to a tool and die shop loaded with the latest and greatest CAD-CAM and CNC toys, and the ability to maintain tolerances down to hundred thousandths of an inch, close enough a 1*F change in temperature causes enough thermal expansion or contraction to measure the change. Such equipment isn't really necessary, but it sure makes it easier. How many $1/2milllion machines do you have access to? I also have 49 years experience building performance engines and drivelines ranging from go-karts to world champion pulling trucks to Ascot trackers to unlimited hydroplanes. Even my airplane is powered by an automotive engine converted to FAA certifications.
No, there is no Tdub2 write up and there never will be. If you lack the tools and skills, you don't need to be taking on a project like this unless you have a mentor at your elbow with the skills and tools. Same goes for the EFI--if you can't do the R&D, don't try or you'll only be frustrated. And if you think a 6-speed TW267 is complicated, try a Honda SOHC CB712 with EFI and electronic ignition conversion.
I'm only making this post because there are good people on this site with the skills and the hearts of good teachers willing to mentor and make these dreams come true. If you really want to get in to such mods, by all means find a mentor, break out the wallet, and get started on a very long and expensive but ultimately supremely rewarding learning curve. Best to buy a 2nd bike, because your hotrod will be down for a looooooong time.
Projects such as these take hundreds of hours of research, planning, and wrenching, and a description of the entire process would overwhelm a website. Then 3 relative newbies would gang up on the contributor like a bunch of punks on a playground and bombard with snarky comments because obviously the person who redesigned, rebuilt, and rides these one-offs every day has it all wrong.
Back to minding my own ... .
